Update:
well, finally got the front disconnected. Pulled one side & went to check it out to make sure that was viable on my truck... works great.
Observation #1, Driving on road is HORRID!!!!!:huh: what a seeerpriiize
Offroad though... it was much smoother. hit a rock with one wheel, and you hardly feel it. Hit a spot where I usually just barely spin... no longer.
Got on a 4' rock (sorry, forgot camera) and found that I could go about 5" higher than before without spinning. The high wheel just barely hits level,(shaft alignment) and the low wheel drops to bottom bump.
I also hit a few mine tailings sidehills, and I was surprised to see that it didn't feel any worse on those than before. I expected the truck to sag toward the downhill, if it did, it was so minor that I didn't notice. One I do a lot, feels like I'm about to flop... it didn't seem any worse. I might bring an inclinometer along on the next trip & compare angle on a sidehill, angle on a rock (I'd say with front wheel on something, the truck is about 5-10 degrees flatter than before. I've got one of these:
that I can bring along for comparison.
Like Bebe said, it's a shadow of what the rear does, especially with the changes to the shocks, but I feel it keeps you in more control, makes the ride smoother, and does allow for more flex.
Glad I did it, I'll post some pics asap, hitting a hard run this weekend I think, so I'll get something by then & hopefully have some quantifiable comparisons for you guys.
