Okay 07Custom...finally got some pics of my Dana44 hub mods.
First is a test fit of my custom caliper mounts. I drew these up on CAD and had them laser-cut from 1/4" steel. They basically have the Dana 44 spindle bolt pattern, but with the ears for a H3 caliper. The holes for the caliper have not been drilled in this photo. You can also see the ABS ring mounted to the backside of the stock GM hub. The wheel studs are 12mm and very similar to stock GM studs. Its important to note that the H3 rotors will be slipping-on
OVER the studs, unlike most D44 rotors that are pressed-on to the backside. Not only does this make future brake jobs much easier, it also gives me much needed room on the backside for the ring and sensor, compared to the stock Dana 44 rotors...
Next I fabbed some ABS sensor mounts from 1/2" scrap I had laying around. I tacked these in place on the brackets so the tip of the sensors are .050" off the rings. I arrived at this dimension by measuring the depth of the sensor hole in the H3's REAR axle minus the length of the sensor body (the part that protrudes into the hole). We'll see if it works...
Then during a test fit I realized that the spindle studs were a tad long, and dangerously close the reluctor rings...so I hit em with a grinder and dressed the ends of em with a hand file...
Next I welded some shims to the bracket ears to center the caliper on the H3 rotor. In a production scenario...an offset would be formed into the bracket itself...but, these are one-off experimental thingys so I went the quick route. After welding...I drilled & tapped some caliper mounting holes in the ears. BTW...the knuckles you see here are not Reiders...they are stock GM flat-tops, machined for high-steer arms. The stock tie-rod arms have been cut off. Here's a shot of the whole thing assembled, (apologies for the darkness)...
The hubs are stock GM 6-lug units. I had to do some machining on a lathe to get the reluctor rings on, and also to get the rotors to fit. Pretty minor stuff. These are early (1973) small-bearing hubs & spindles but, I don't see any reason you couldn't do the same with the large bearing (and more common) hubs that most D44's came with...
The end result is a Dana 44 solid axle with H3 4-piston calipers, rotors, and ABS/TCS ability. Very cheap. Very simple. Very available...and it uses all over-the-counter parts....
But don't count your chickens just yet...this has not been tested. I'm 99% sure this will work. I'll let you know later this spring. You could do something similar to your Dana and probably get all those dash-lights to go off.
