derian06
Red Rockett
- Madison, AL
I ordered mine yesterday! Can't wait till my 50" and my light bar mounts come in.
How did you install it? And how hard was it
I used the Hummer H3 G2 brackets to install the light bar. Installation was straight forward. The brackets bolted to the existing a hole on the plastic windshield covers. (Located on the side of the cover, under the weather stripping) This existing hole will be used as a guide to drill the other 2 holes. The Light bar bolted right into the brackets. I didn't do the wiring but the wiring was ran under the drivers side plastic windshield cover. Through the cab, under the dash.
It took about 1.5 to 2 hours, but now that i have done it, It would take me less than hour.
Yeah mine shipped today but I'm nervous as hell about the install
I'm sure it won't be too bad, and if it is it's worth it.
Do you mind taking a closeup picture of the bracket installed?It's just the drilling part... If I mess something up I'm screwed
1289mm
Damn... Do you think my 51.6 inch will still fit the g2 mount?
It will be tight but i'm sure a 1 inch difference won't kill you. Mine is 50.66"
I emailed the g2 guy and he said it won't fit lol... He said I need to tweak the mount
Tweak it how?
Probably bending it back alittle so it fits. If it really doesn't fit I'll just returning the bar and get a 50
You sure its a 52" it's probably the same size as mine but it's counting the mounts that it comes with. Its a 300w right?
Thats .4 inches for both mounts and that doesn't make any sense, so i think you're good.
Also mine is 51.6" with the mounts.
Yeah I hope so man... And our h3's are gonna look badass with the light bars
they don't need lighbars to look badass.... just sayin' :salute:
I went with a cheap 137$ Ebay bar, but DANM they are bright. The only negative reviews i've seen is from condensation inside the lens. So when i pick mine up i'm going to re seal the edges and i'm thinking i'll be fine. I'll put up a review if anyone wants me too. I mean if i'm wrong its only 137$ vs 500-3000$ for any other 50"
