Lewiz VenomH3
- US
Got a new muffler coming in tomorrow. Bought a magnaflow super 10
In my opinion yes, the pic I posted should be behind the resonator.Should I remove the resignator too?
After flooring it, there is a smell, only with the windows open though.Have you smelled exhaust fumes in the cabin?
Ok so after i cut the pipe how far down should I put the new muffler. Got a super 10 coming in tomorrow.
Just had it dropped low enough to check drain tubes. What are you looking to do?anyone ever pulled the headliner off/ have any pics of it completely off?
Has same issue with my mtx 9500s. Just made different box facing towards rear door.I have 4 12's in the back on 3200Wrms with subs up and port up, so everything is bouncing off of the thin metal roof. planning on getting thin strips of birch conturing then to the roof and glueing them on with epoxy. then another lair with wood glue/screwed into the first lair. Then bracing with some flat bar steel or something. This should stop the flex and give me a sturdy roof. Just wanting to see what I have to work with, if any of this will even fit/work with the headliner before I take the time to drop the whole thing.
Have you tried dynamat?
There's this guy in fb in H3 off-road who completely took out the headliner doesn't looks so bad...but if only do that if I was to turn panzer into a canvas soft shell.anyone ever pulled the headliner off/ have any pics of it completely off?
I've thought about using an actual deadening product, but why do that? When I can do it myself, cheaper, and have a better finished product.
My box is absolutely maxed out as far as space goes, so there would be no way to have subs or port back without losing that precious air space.
I couldn't see anything out of the back anyways, 37" spare. Amp rack is beneath the box.![]()
Does anyone know what this tape covers? It's on the passenger side right below the windshield where the pass wiper is.
I was replacing my vent cowl today and noticed water was pooling here. I didn't remove the tape as I didn't want to let water in. I'm assuming my old h3 had this and others do as well. Only way to see it is if you remove the vent paneling that goes where the windshield wipers are.
Sent from my SM-G930V using Tapatalk
The tape is there as a spacer/padding for the dash I believe. I shoved mine back in after I replaced the heater core.
Installed Rock lights, rigid radiance pods, new exhaust and tips, dual batteries, vair compressor and air horns from hornblasters.
