poncho1965
- Ridgecrest, California
Got mine finished today. I'm a beginning welder so nobody gets to see pics of my welding :wink:. it went pretty smooth though, the holes on the Cbphoto winch plate needed to be reamed a little wider apart to match the holes on the recon, and I had to cut out a cross member on my grill guard. I'll try to find some of the same material to weld in a little higher.
The holes on the winch plate fit my recon to a T. I had checked before and found it has the same bolt pattern as the recommended Warn. I also had to grind down that cross member on the grill; the width the reinforcment plates added made it impossble to put the bumper/grill where it needed to be. For the reinforcement plates, I had to bevel them to get them to clear the original plates welds and fit flush against the original plates. In the end it worked out great! Since I don't weld I had some of the local rock crawler guys throw the plates on for me
