TAPDH3T's H3T Build
That's a ten minute swap....just support the truck from the frame, spin the torsion bolts loose, and pull out the torsion bars and those drop brackets. While you got it apart check to make sure the torsion bars are on the correct sides (RH to LH) and also check to make sure you got them oriented (front to rear) correctly. If I recall...the bars have blue tape and yellow tape on them, to differentiate them...and those tape lines goes toward the front. All six items (2) keys, (2) bars, (2) drop brackets must be install properly for it to work right. Its like a Jenga puzzle! The sad thing is...GM should have "keyed" them left & right and front to rear in the first place. In this day & age, this is totally possible and thats what Toyota would have done. Instead...dumb ole General used a simple "hex" shape at all four points, that allows anybody to easily assemble the parts incorrectly in one of numerous combinations. Duh!
You'll probably have to take the front wheels off and drop the lower A-arms as low as possible to get things indexed correctly. Sometimes it helps to have a buddy stand on the knuckle to get the suspension to the full-droop position. Only then can you get the "hexes" to line-up properly, and get the torsion bolt started. You should just barely be able to get the torsion bolt started into the key with the A-arms at full droop. Doing this will insure that you have the entire bolt available to set the ride height. The way it is now...you're running out of threads long before you reach the desired torsion tension. You'll see what I mean when you get it corrected.
Technically you're supposed to use "torsion key clamps" (large C-clamps) to pull the keys down into place inside their pockets. Then tighten the torsion bolts accordingly. Using the threads in the keys to put pre-load on the bars is not a good idea but, it can be done. Put a big glob of grease on the threads of the bolts and the inside the keys to keep them from galling. I've seen torsion bolts seize and strip!...so be careful. Always make your ride-height adjustments with the wheels in the air. Don't crawl underneath and crank on the bolts while the full weight of the truck is being carried by the suspension. Instead jack it up from the frame first and let the wheels dangle....this will ease the stress on those threads.
You'll need another alignment when you get done fiddling with it.
TAPDH3T
Texarkana, Texas
Lmao! That's what I thought when I posted the pics... Sweet!! I will have to jump on it Tuesday!! Dang Chevy mechanics!! Lol
TAPDH3T
Texarkana, Texas
Ok got everything out and switched over.. Before I get to involved in the re-install the tape goes toward the engine bay??? I believed he also had one bar upside down cause the tape was closer to the rear end on the driver side
arkalpha
arkansas
I'm at work, but I am almost positive the tape is to the front. If no one chimes in, when I get to the house I'll verify and get back with you.
TAPADROID
arkalpha
arkansas
Do you have the installation guide for the kit? I'm not sure but could the shocks, if they weren't loosened, have kept the A arms from dropping as low as they should? If you don't have the manual you could always download it. Wish I knew more about it. Hopefully a more mechanically inclined person than I am will see this and chime in.
TAPADROID
TAPDH3T
Texarkana, Texas
Alright everyone, I turned a 10 minute job into an 1.5 hour job.. Lmao
Not only were those shackles backwards but the keys were placed in a downward position..
(What it should look like with bolt out..)
That's why there was no lift.. Well common sense would of said when I went to take the bolts out and there was no pressure on them that would of been a sign but NOOOO!!!
I finally figured it out and got it leveled out with plenty of room to go higher if needed.. So for ur viewing pleasures...
arkalpha
arkansas
Heck yeah. Now that's the way it should look. Does it still fit in the garage? It looked close in an earlier post. Congrats though. Looks good.
TAPADROID
TAPDH3T
Texarkana, Texas
Thanks! It has right at a 1/4" between the roof and my bungie hooks.. They can be removed if needed and that will give some more space!! I'm going to keep and eye on it just to make sure the truck doesnt decide to raise up and take a bite out of the roof... And ur right level 2 for them shocks are perfect for them Arkansas Roads!!!
ABNTROOP - LMAO
arkalpha
arkansas
ABNTROOP - LMAO
Cool enjoy
TAPADROID
SolidusJ
FT. Carson, CO
Glad it worked out, you should still get with the people who did the kit and just let them know you had to clean up behind them to get it right. SO trip to hidden falls in August? From what Longknife 6 put out we should be on leave by the 10th of August.
TAPDH3T
Texarkana, Texas
Already did lol!!! The baby should be here by the second week of July so I can't promise anything.. But it's early enough that if we set something up I can sneak away lol
Looks much better. I'm left dumbfounded with some of these techs. This guy uninstalled everything and then reinstalled it...not sure how he could of messed up.
SolidusJ
FT. Carson, CO
Good to know and my baby boy was born on July 18th and turns 5 this year, I think I'll take the wife and kangaroo with me this time.
Attaboy! That's how its supposed to sit.
The key is making sure you start with the torsion keys at a very steep angle...that way you got enough bolt left over to get some pre-load "CRANK" put into the suspension. Sometimes you gotta sit and stare at things awhile...but it looks like you got it. Nice looking rig.
Now for some bumpers!
:wink:
