Speaker question
I've noticed that after a good wetting (rain, melted snow, etc) that when I roll down my window and roll it back up the window will be all covered in water droplets. I'm not sure if it's just the wipers hold a lot of water in the velvet part amd that is where it comes from or if the seals are going. Ill be pulling off the panels later to install some mirror heaters and can take a look then. Might be related, might not.
You could also look at adding those speaker "cups" or baffles or whatever they are to help keep the water off of the speakers. Though it is concering that you have that much water getting in. Has it been raining a lot where you are at?
Sent from my SM-N910T using Tapatalk
Ghostbuster
Yeah my neighbor said that it could be those seals, but it would be pretty ironic that they started leaking right after I installed aftermarket speakers. So either the factory speakers kept working with water dripping on them or those seals all went bad at the same time, and right after I installed new speakers...
