Going back to the BCM topic, I have needed to replace my BCM when I was stuck at the bay side of South Padre Island. I was about 1/2 wheel sunk in muddy clay like sand. What started out as fun in the sun turned out to be a night of survival until help arrived the following morning.
I didn't know this but on the bay side of the island, Water comes from underneath the ground especially in black muddy areas. The water then recedes on low tide.. Well we got to witness this first hand over night until help arrived. .
I panicked a little but then came to acceptance that my h3 would be ok if I just did not turn it on. . and that I would never go to the bayside of the island again.
in the background you can see the evidence of friends and I using shovels, boards to get me out without much success.
Close up
The tide finally recedes. I had to use a towel to cover the sun from burning us, Nice Sea breeze though.
From a distance in the morning.
Help arrives, Oh did I mention they also got stuck in the deep sand area.
This is How they did it to get me out. they came prepared with boards and a very very long tow extension.
Cost:
Towing: $250
BCM: $600
An Adventure I will never forget: Priceless
(I have more pictures I can post on another forum)
Sure.. . a snorkel would of helped but the factors involved in this were too great.
The BCM eventually gave out causing the computer to freak out. I was at the Guadalupe mountains national park when all of a sudden the brake lights went out. Found that the fuse to the brake lights would pop ever time I replaced it with a new one. so rigged a fuse to prevent the popping but noticed it caused one of the brake lights to stay on as if there was a short some where. So I had to take the fuse out and drive with no brake lights. The odometer stopped working after awhile as well. I took it to 3 mechanics and no one could find the short. . so eventually just replaced the BCM.
- Lesson learned. Use the right tires. protect ALL your electronic connections!
- I am still looking for a way to protect the BCM as that the electronics are the main things affected.
- I also wonder if having a small 2.5" lift would of helped.
