Any way we can get a sticky of this of tread? With parts number list on the front page? I've seen a lot of forum members asking for a parts list and I think if we just had a sticky of it, it would make it extremely helpful.
What's the size and specs for the brake cable?
Flex testing...make sure your bump stops, shocks, brake lines, and ABS lines are all coordinated with each other. Having correct lengths on this stuff is critical...
Here's an early shot right after I did the SOA (still had Rancho shocks). You can see the huge gap between the spring and the bump-stop...so some extension towers were in order....
These were made with some 3x3 box tubing and some plate steel. Additionally, I chose aftermarket progressive bumpstops (on the table toward the rear)....
The new bumpstops required some 2" spacers blocks between them and the frame. The factory rear bumpstops were cut-off and used on the front axle...
I welded my lower shock mounts as low on the tubes as I could get them, trying to get as much travel as possible but not giving up any ground clearance...
Can't see the pics... Is that just me?
Is there still no way to get just the front rancho?
I know Rocky Road outfitters here in UT offers the old man emu lift.
http://www.rocky-road.com/h3-lift.html
Ya that's what I saw. I am going to ask them tomorrow about what it exactly "does". If it offers a beefier torsion bar (ie alpha type) that might be worth looking at for some. I was looking to get a little more lift than that though.
The "advanced" uploader has not worked for me in over a year...so I'm forced to use the basic uploader.Probably user-error...I'm dumber than a Miss America contestant when it comes to computers.
