Azjohn
- United States
I got the check engine light for P0140 and changed out the o2 sensor like it listed (Bank 1 sensor 2 post CAT) with an ACDELCO OEM 213-3908 . Cleaned the codes and the error returned. Checking the ODBII readings for the O2 sensors (I didn't realize i could do this before I changed it out) I'm getting a voltage of 0.0V to 0.8V for sensor 1 and a solid 0.4V for sensor 2. What should the voltage be, and also any other ideas on what the issue could be to through the P0140/P2A01 codes?
Thanks!!
Thanks!!
