H3 LED Foglight Brackets
CaddyStrophic
Well, I haven't heard anything from this guy, so I'd say 4-5 sets went enough for him to fool with.
On the other hand, they really aren't that hard to make yourself. So I'm doing a test-fit of some that my buddy mocked up based on the blueprint from Adventure.
Which brings up and unrelated issue. I ordered the 5-round led lights and the eBay seller sent me the 4-inch. Currently waiting on them to respond to get my money back or a new set sent out.
If I can get these brackets made up and fitting correctly, I should be able to hook everyone up with a cheap set. I can't imagine any more than $35 a set.
H322
I would also take a set! I have the lights already just needs brackets ASAP
Ron46
Capt.
NJ
Nice! I have been waiting for many months for pair of mounts. I have been staring at the LEDs on my desk for too long lol
I took him a new sheet of 16 gauge steel today and asked him to make some.
If we get enough people together oh are interested in these brackets I will do a run for 5 to 10 with a local builder that I have been making a lot of other projects with.
Its a waterjet shop that makes stuff out of mostly aluminum and stainless so they should be able to bang these out no problem!
I've got a couple sets leftover but the problem is they no longer produce those lights
Sent from my Pixel XL using Tapatalk
That makes sense, I couldn't find those lights for the life of me after posting up the offer.... Well I found one, but does me no good!
bigwilliedw01
US
does any one have a set laying around they don't want ?
I have the lights and the brackets at home, but I can't get to them until sometime in June when I return from Afghanistan. If you haven't found a resolution by then, your welcome to them!
Sent from my SM-J700H using Tapatalk
Ghostbuster
I put these 4.5 inch led light in mine.
They only cost about $50 for the set.
I just had to cut the lens off of the original fog lights, cut a hole in the back of the original fog lights, then Jb welded them into the original housings. Then I popped them back into the oem mounting bracket and bolted it back it.
They are plug and play.
https://www.amazon.com/dp/B01E69KPFU/ref=cm_sw_r_sms_c_api_dCM5ybXF7WG28
