H3nightrod
- Illinois
Hello everyone
Well I’m seeking some advice on what to do with current issues on not being able to pass emission test.
As of now I have done the following work:
engine tune up with new plugs, new exhaust manifold both sides due to leaks, one cat, Evap system, carbon canister, and o2 Sensors.
Before the evap replacement the truck would have a rough start after refueling. I tried to fill up while running and idle was all over the place. This is no longer an issue. However twice I have had the check engine light come on right after refilling and driving a few miles.
The last code I got was PO13B O2 slow response, again right after refueling, however that sensor is new so don’t think replacing will correct this issue. Could it be I need a new fuel cap?
So today I took it to local shop and they suggested to re-flash or update the PCM. Has anyone ever had the update fix an issue similar to this? I kind of don’t see how this would help but then again I’m not a mechanic. I am a little hesitant to do this because I had my PCM tuned about 8 years ago to match 4.56 gears and don’t want to lose this programming.
Any info and advise is greatly appreciated, really need to pass these emission test as my tags have been expired for some time now!!
