Schwarttzy
- Rockford IL
tires-chirping, wheels-spinning, front end bouncing approach that I would consistently experience previously.
Don't take this personal, this is just web wheeling and I never met you and I'm just going with my current intuition, but my mind is telling me that you might benefit from more experience off-road. Unless you have a manual transmission, then I completely understand what's happening. However, I have never experienced a situation off-road where a lower t-case gear ratio was the difference between making it and not. What I'm thinking, and I could easily be wrong, that the lower gear ratio is forcing you to drive differently and that has been making the difference. To me, the tires chirping, wheel spin, and front end bounce are all signs of "needs more experience" and less to do with the t-case. Then again if the t-case forces you drive better, I couldn't argue against that.
Off topic, but I think about having a 3 to 1 t-case from time to time because I think 4 to 1 is too low. Maybe if the shift points were difference on my vehicle...
