What performance mods you got?
backcountryislife
Dumont, CO
No accessories, bumpers, sliders, no racks... Nothing that does not directly affect performance.
JUST mods that make it faster, higher, more capable, whatever.
Seeing the TomP shock mounts last week made me wonder what else is out there that would make a big difference that I don't know about.
My truck does well, but always looking for the next step, if I can find someone to copy the OKoffroad plates, that'll be next, and the locker is coming in a few weeks, but wondering what else is out there!
I had a buddy build a RC track on my property,
so I spent some of my locker money on some parts for a car he gave me... been having fun with that, but now it's time to get a few things done on the H3.
Whatcha got????
Paladine71
ΜΟΛΩΝ ΛΑΒΕ
Tallmansville, WV
Magnaflow Dual Catback Exhaust, Tuned TCM/PCM, Airdoc Intake, Dual Optima Yellowtop Batteries, Dual Battery Power Management, Safari Snorkel, Sy-Klone Pre-cleaner, PCMforless Electric Fan, Rear Swaybay Quick Disconnects, Extended Rear Shackles, Eaton E-Lockers, etc. etc. etc.
I've spent way too much money! :roll: :wink:
Reloader
Montana a free state
Magnaflow muffler with custom built tailpipes tucked up high for clearance, Airdoc intake, safari snorkle, PCM tune, Eaton rear e-locker, cranked T-bars, and a performanced enhanced custom built three flanged javis with triple interlocking gizmos, a chromed, not galvanized dohicky retained by titanium reversed inverted left hand threaded safety wired belville washered triple square nuts.:giggle:
And more stuff in the plans.
backcountryislife
Dumont, CO
Hey cheesehead, any pics of how they tucked the exhaust? That's something I could do for free, but not sure where to put it.
I was just in Sauk weekend before last... and I'm already out of cheese curds, want to make a trip to CO & bring me some??? :D
Hmm, pcmforless tune. Torsion bar crank. 4:1 transfer case vs. base. Added Eaton rear locker. Tomp lo-pro shock mounts. "Clearanced" rear bumper. Full synthetic blinker fluid.
H32NV
Golden, CO
Optima battery, 35's, extended bump stops, 2.5" custom lift, high-clearance custom rear spring hangers, bar-pin delete, bilstein 5100s, eaton rear e-locker, 4:1 transfer case, AMSTAR Beadlocks, GREEN high-performance air-filter, PCMforless tune, Magnaflow custom exhaust. lead foot.
Rancho lift for added clearance, deaver springs to actually retain the height in the rear, rancho adjustable shocks, tomp low profile shock mounts
K&N filter, air doc, magnaflow exhaust.
Added rear locker
Future mods... PCM tune, 4:1 T case, CI diff w/ front locker, custom spring over and get rid of the low hanging spring hangers.
Then ill be able to conquer the world :)
kflips
Virginia
Billy boat Catback Exhaust, Tuned TCM/PCM, Airdoc Intake, Dual Batteries, Dual Battery Power , Extended rear sway bar, Extended rear shackles, raptor II transmission w monster sun shell, 4:56 gear ratio on diffs, Thor front drive shaft
I've spent way too much money too
D
Dennis
Nothing Serious..
  • Gibson Dual outlet cat-back...
  • K&N CAI..the nylon tube version (Metal tubes conduct too much heat to the intake air..Hence defeating the purpose of a COLD Air Intake..)
  • PCM retuned by PCMforLEss.
  • High speed Chrome Lugnuts
Hans3T
Lif"T"ed
NC
Well...in terms of on-road performance, I've got a Superchips, AirDoc and K&N filter.
I'm looking into a performance muffler. I believe the Alphas would require a 3" inlet and outlet. Can anyone with a custom exhaust confirm that? I'm looking into a 40 or 50 Series from Flowmaster eventually.
>Sent using Tapacrack<
I have a V8. Good enough performance for me. All mods are done to clean up and make things more reliable.
Sent from my iPhone
backcountryislife
Dumont, CO
Maybe I phrased that wrong, I meant offroad. I'm looking to find what else works that I haven't tried yet. (recon & bebe... you're disqualified!!! I can't afford what you two have done!!! :wink:)
I've got a cold air, and a dual exh., the shop I ride for has a superships account, so I'll probably do that at some point, but I'm looking for whatever will keep me going up the hill mostly... and I mean a hill full of rocks! :D
backcountryislife
Dumont, CO
Oh, well for that your going to need the full "anti-gravity suspension kit"
:thumbs:
Can you start another thread & explain how that's done... That looks like a great idea. I'd prefer to float about 4' above the ground though... only looks like you've got about 2.5' of clearance, can that design be improved upon???
For offroad performance I would start with where you get hung up the most...probably the spring hangers right?
backcountryislife
Dumont, CO
well... that was supposed to be the point of this thread, but obviously I worded it wrong. I was trying to find solutions to the issues I've got, and see what other people have done.
Spring hangers, have yet to see a single solution other than SOA... and I'm not going to do that without a better idea what/ how to do it.
shock mounts, I've seen two solutions, neither of which are still available
lift, I've seen the two specific lifts, not sure what else I can do on the rear, thinking about a junkyard AAL, but I have yet to see anyone who has done that.
I just don't see a lot of options on here when I look, so I thought I'd ask... but not getting much in the way of what I was hoping for.
cbetts
NERD!!!
Rancho Palos Verdes, CA
Ah! In that case, here are the other mods:
  • Hunner 1/4" front skids
  • B/A Rear skids
  • OEM Undercarriage Protection
  • BFG KM2 Tires (315/75R16)
