H3 Water leak
ludevick
Northern California
Wellllll it’s been raining the last couple days up here in Northern California and I noticed the driver side front carpet is soaked. I cut out a portion of the carpet to help it dry out and will be leaving a tarp on it to hopefully prevent more water getting in. I don’t have a sunroof and am wondering if there are common places to check for leaks. Thanks in advance! Also noticed a bit of water in the doors which I’ve heard isn’t a huge issue.
•I will try checking out the plastic roof trim and all of those bolts tomorrow.
PS I also installed a new head unit, CB radio and door speakers. I was very excited until I noticed the leak hahah ugh.
ludevick
Northern California
No roof rack but the front driver side bolt was very loose (how?) so I took it out, let it dry out and tightened it down. I hope that fixes it. Thanks for the advice!
I drilled out a piece of plastic square stock and cut it to length to match the height of the roof trim, filled the gaps with black silicone and no more puddles of water.
