Steering Stabilizer
Cajun_Tiger_Hummer
Lafayette, La
I have a aftermarket one on order since I'm still running the original one (9 yrs old). Steering has a slight looseness to it. Hopefully this solves the problem.
Anyway, how hard is it to install my self?
twinmill28
Spilled Milk
Loose steering shouldn't be the stabilizer, could be worn parts. The stabilizer is supposed to slow rocks and potholes from jerking your steering wheel out of your hand when you come upon them.
Installing the new stab isn't too complicated, you'll need to drop your skid; I used my floor jack to hold it while I unbolted it then lowered the jack, held the skid steady and pulled it out from under the truck.
While you're doing this, put the jack under each lower control arm enough to get the tire off the ground then give your tire a shake left to right. There should be no play there, if there is, replace tie rods (if you look at the actual joint connection you'll see the movement if it's bad). If there's vertical play in the tire (use a pry bar under it) then replace your ball joints. While you're doing the tie rod check grab the pitman and yank it around, if it moves replace it along with the idler if you're going that far. Be warned though that to replace idler/pitman you'll need to unbolt the steering box and all of that takes some muscle. It's not hard, it's just better work for a guy who hasn't sat his a$$ in an office the last few years (me).
It's a fact that these front ends loosen up all the steering parts after a few thousand miles. I spent about $300ish to replace all but the steering stabilizer and shocks, I want to get back under and get those done. I used all Moog parts, available and cheapest from Rock Auto .com
The Moog are the best replacements you'll get without going to the super heavy duty aftermarket stuff.
Scarsman
Monroe, WA
Everything he said. If you have looseness I would put money on your idler arm and idler pivot first, then your pitman.
I'm running bigger tires and go off road, so I went worth the Kryptonite parts from the Dmaxstore.
twinmill28
Spilled Milk
No comprende' Scars--the idler pivot doesn't do anything other than just hang out and hold the idler, there's really nothing to go bad on it. I replaced mine because it was cheap and everything else was going to be apart, but I'd really put the pitman being bad before the idler.
Oh yeah, the zirc for the idler is non-accessible without removing the skid plate meaning they normally never get greased during the life of the front end. When you replace the idler make sure to get the Moog with the zirc extension hose that makes the zirc accessible without pulling skid plate. Mine was a biatch to get in there, the space and angle was tight but it's nice piece of mind---and it doesn't cost any more for the parts, just make sure to get the kit that has it.
Humvee21
Atlanta, GA
Wish I saw this thread before I replaced the brakes and front bump stops on Saturday.
Sent from my HTC One_M8 using Tapatalk
Cajun_Tiger_Hummer
Lafayette, La
So here's the conclusion. It's my idler/pitman arms that need to be replaced. Steering stabilizer will be replaced as well. It's beat to crap. This is all getting done Monday. Parts are sitting on my kitchen counter as of yesterday. In the mean time. Tomorrow the monster 41s are being replaced by even bigger 42.5" tires. Thanks to Interco. So if any one wants to buys 4 used 41 x 14.5 x 20 iroks they are for sale $275 a piece. All four still have good tread. And I have 1 brand new tire. Selling for $425. If interested. Tires are located in Lafayette LA. PM me and I'll text you pics.
