Shakedown Moab run....
Ahh that's the mud we have! Cleaning the tread is not an option lol. I would get a permanent mounted winch and one that is removable for the rear. Id probably leave it in the back or at home whenever I don't need it. I do to much rockcrawling to have it on there 24/7...
Btw hunner, Every bizarre steering symptom I have had stopped since I went in the mud...Hypothesis is that Off roading cures problems :woot:
Hunner
Arkansas
Yeah packed mud will work wonders, never wash it!! Probably tightened up everything, for now.
Check that rack tube at the steering box.
No worries dude, Good deals come and go, you cant get em all. Now I just need to build my own...I really need the fab practice to get better. lol
Sierra H3
Central Sierras
Cleghorm gets pretty slippery after a rain. But, the worst I have seen was Hungry Valley when snow was melting leaving some ice and mud mixed together. My Duelers were useless. Had to use momentum going down a hill to slide up and over the top of the next ridge. Broke a bead on one tire doing it in a rut. But, gave my passengers the best roller coaster ride North of Magic Mountain! I was not well prepared in either of these cases. Us SOCAL guys just don't get into the stuff regularly and so we tend to get caught off guard. Good that you came through it Chris.
I feel most tires are useless if you cant clear them out and the type of mud I was in they just stick to the tread.
I actually went back to the trail today and took video and really tried to replay the situation in my head.
Over the past few days I have been doing a lot of thinking about that scenario I was in...I just cant figure out what would have been the ideal setup for something like this. While you cant have the "perfect rig" because each scenario brings different approaches...Sometimes a long wheelbase is good other times shorter wheelbases are better, trackwidth can vary and even the amount of flex can help or hurt a situation, IFS vs. solid can depend on the how you fare in getting out of an obstacle...I am just trying to learn more about my rig and what I could have done (other then avoiding the damn hole, as in your already in the stuck situation)
I felt like tire placement could have totally changed the situation too. Now bare with me here but thinking about a Solid axle I think I would have been safer with the front tire in the hole seeing it would flex out and provide stability...In this case I think the IFS was better seeing my front tires werent in the hole, The suspension works independently and allowed the front passenger tire to drop and put weight lower whereas a solid axle with the front tire out of the hole would of forced the passenger front tire a lot higher seeing they are dependent on each other. I am sure that probably confused the hell out of you guys but after re reading it a few times it would make sense.
I am just glad I got out of the damn hole safely, 2 things I learned, #1 Sounds corny but teamwork, creativity and patience really can safely get you out of a bad situation. #2 Now that I was in this bad position I will use it as a thing to base future modifications off of. As recon build his rig accordingly to the terrain he has tackled across the world, I on a much much smaller scale, can use this to help build up the hummer better. In this case I truly believe the trackwidth helped, still any little change in terrain or placement could of helped a lot or hurt a lot...
will get the video up soon
me standing in the hole
[video=youtube;pKcDI1q5WuA]http://www.youtube.com/watch?v=pKcDI1q5WuA&feature=youtu.be[/video]
@45 seconds, obviously he knows more then me...I sat inside the whole time holding the steering wheel he was setting up winches
