Reputation?
Paladine71
ΜΟΛΩΝ ΛΑΒΕ
Tallmansville, WV
How is the reputation indicator set up? I've noticed that some people have nearly 200 thanks and they are still at the same "one green block" that the rest of us share. :huh:
08SolarFlareH3
Super Swampers
Finger Lakes, NY
Maybe it has to do with post count? Maybe it goes to 2 blocks when you hit 1k? and 3 blocks for 2k and so on. I am sure Alrock will know the answer.
*edit,
Well, I just noticed 3Hummers have over 1k posts so if its based off posts its over 1k
05Mudiak
Lake Charles, LA
on the bottom of a post you have a star next to the thanks and if someone clicks on that and approves of our post your rep goes up, you can also disapprove a post and I assume you use rep points
Some idiot (aka me) had Thanks turned off and not affecting reputation. It is turned on now and I will see if I can get it to update. 50/50 chance.
