Renagade132 mod thread
New Jersey
Hello everyone, I am glad. I found this site, and I am very happy to be part of this community. Here are some of my mods as. I can best list them. I have some older pics, but I will have to search where I stored them!
I'm trying to keep a list of what I have added and will add, but so much is happening at once in my life, I apologize for the lack of it being organized.
-Had interior leather seating all redone from the cream color to black leather, all pleated like the original seats, including heated seats reconnected.
-HIDs installed on headlights.
-installed super bright lights (will check the name) on the bumper spot lights that are also ballast driven, to make them brighter.
-replaced all exterior bulbs to LEDs, including turn signals, that switch from white to Amber as they flash, so they can be legal for use.
-replaced all interior lights to LEDs as well, there were over 18 LED bulbs to change.
-changed all exterior lights to smoked lens, including 3rd brake light at top in the back.
-installed rear black tail light guards
-installed smoked window visors
-installed sunroof visor
-installed a Havis laptop swivel mount
-installed front 2" tow hitch adapter to allow a regular tow hitch connection to attach (for some reason the factory one is mounted Verticle so a regular tow will install in the wrong direction. I temporarily installed a mini vault with combination (cool to store extra key, cash, or credit cards)
-I currently have a 12,500 lb winch (Tuff Stuff with wired and wireless remote) that is detachable on my Chevy Suburban, that is mounted on a plate with a 2" tow hitch sleeve, that I want to use on my Hummer if need be. I already ordered the quick connect plugs, which I will run the connectors to the front and back (I ordered quick connect 16 foot jumper cables as well) that way I can connect the winch in the front or back, same goes for jumper cables, in case I have to help someone.
-installed E&G wide body fender flares (made a huge difference, made the wider wheels not stick out as much)
-installed Boria Titanium headers
-installed a Gibson dual cat-back y split exhaust and muffler with stainless chrome tips (gave the truck a wonderful sound)
-had top of front windshield tinted
-had bumper spot lights and bottom fog lights tinted
-installed outer Snorkel unit. Custom installed inserts to make it removal
***will be installing soon***
-Fabtech dual steering stabilizer---Will not fit if you have a lift kit on the vehicle!!!
-upgrading alternator to a 300 amp alternator-INSTALLED
-Upgrading to Brembo drilled disc rotors-INSTALLED
-upgrading to Brembo brake pads-INSTALLED
-installing LEDs on my dashboard lights (the halogen bulbs will have to be cut out and the new white LEDs have to be soldier back in)-INSTALLED
-installing the Air Doc performance intake with my already installed K&N filter-INSTALLED
-installing an IPad mini dash mounting plate
-installing a iPhone cell phone mount on dash
-installed a much deeper Trans pan (will hold at least an additional 3 quarts of trans fluid as per mechanic
-using Royal Purple fluid where ever possible including differentials.
-K&N oil filter, all oil switched to Castrol Synthetic
-sound system will be my next project, including a Double din full screen head unit
*** hopefully in the near future I want to get the Evolution CTS unit to control power, torque, and gas savings during different situations.-PURCHASED AND INSTALLED, will update on progress
-if anyone has any questions on any of add on, please ask away! What I can't answer, I probably can get my mechanic buddy to help me answer, as he is the one that has done the work with me, but is also a professional mechanic.
Great looking rig and welcome. Any more pics?
New Jersey
Black screw on tail light protector brackets, rear tail lights OEM, but had them tinted with a special extra thick and flexible exterior tint paper. All rear tail light bulbs switch to LED.
New Jersey
Whelen HH2100 hand held mic and emergency light control head unit. (Will control all emergency lighting I will be adding soon to the truck)
New Jersey
My lights lit up during day. I disconnect my daytime running lights and connected them to my regular lights, I hated that they only worked during the daytime, so it was hard to even know if they were on before!
New Jersey
I had my side front and side rear converted to Multi LED, they stand out a lot more, and look a hell of a lot better. Then installed smoked covers over them with the chrome trim, but I think I am going to get rid of the chrome, or at least paint them black too.
LoJac963
Surprise, AZ
Looks good, I have been wanting to find some broken side markers to play around with installing LED strips also but to where the entire thing would light up. You pic next to the Z3 is so funny, it was the same when my wife had her Sky Redline. I couldn't even see her behind me in that little car!
New Jersey
Thanks LoJac963, I used these particular LED strips because they are flat, waterproof, and can be cut as short as you want. The strips my sound guy gets can all be cut. Unfortunately technically what you cut off will no longer work, but like I said technically, because if you soldier the wires correctly, the rest of the strip will work.
