- Bellflower, CA
So I thought I had fixed my leaking drain for the sunroof. After a bath last weekend the carpet was wet again. So I started with a small piece of 14 gauge wire to push through the tube, after I heard it wiggling around the head liner I knew the problem. The tube had come free from the drain fitting. All my own fault.
I cleaned off the dirt, added a dab of sealant, and zip tied it to the fitting. That should keep it on.
Note to everyone else. DO NOT USE AIR OR STIFF WIRE TO CLEAN THE DRAIN.
