telemike
Hummer Enthusiast
- Greensboro, NC
Thanks to PCM of NC programming my PCM, Passlock is now turned off. This
morning, I hop in the H3, turn the ignition and it fires up. Meanwhile, the BCM
is blinking the security light because it failed to get the proper signal from
the ignition cylinder. Yay! I don't have to wait 10 minutes to re-try starting
the H3. So I drive for 10 minutes with the blinking security light and then it
goes off. I highly reccomend having PCMforless turning that
passlock
off if you have them tune your H3
WARNING:
This is not reccomended if your H3 is under warranty, you have an active OnStar subscription or you want to keep the OEM security system. This is an optional fix for those with passlock ignition cylinders that do not function 100%.
WARNING:
