USMC_315
- Northern VA
Hey guys,
I've never worked on t-bars before, nor have I ever had them worked on, so I'm really in the dark on this one. Like I may have mentioned in my build thread and possibly somewhere else, the measurements between center of the wheel and fender are both different on the front end. I was reading this thread, which was helpful until it turned into a comment war. :slapfight
I also read a few other threads and I'm somewhat starting to understand what I need to do.....but I'm not quite there yet. Sorry for all the questions that will follow...
As always, thank you in advance for any help!!
- If I crank the t-bars, should I install new shocks?
- Are torsion keys that were mentioned in the above thread a better solution than just cranking the T-bar itself?
- Will leveling it actually put me at a higher risk of them breaking in offroad situations?
- Could an uneven/unbalanced t-bar be the cause of my front bumper to be uneven with the grill?
- Should I crank my t-bars before it goes back to Carmax for servicing since they'll probably be doing an alignment for my front end shaking?
