H3 Light bar wiring
stealth 07
Georgia
I plan on getting a bolt together defender rack and fabricating another segment to make it longer, around halfway up the front doors. I'm having trouble with finding a thread about wiring aux lights from the rack and down the a pillar. Is it possible to run the wires under the plastic molding with the metal railing up top or will I have to cut into the plastic to get the wires to the a pillar?
IISPEEDYII
Pennsylvania
I was able to slide the wires right under the a pillar trim and the roof trim. With a little muscle it went right under the trim. Watch the clips though. They're pretty fragile.
derian06
Red Rockett
Madison, AL
This X3 but i'll show you how it's done ImageUploadedByTapatalk1412870515.273885.jpgImageUploadedByTapatalk1412870527.661683.jpgImageUploadedByTapatalk1412870545.705297.jpgImageUploadedByTapatalk1412870566.866687.jpgImageUploadedByTapatalk1412870595.214180.jpgImageUploadedByTapatalk1412870609.035749.jpgImageUploadedByTapatalk1412870651.640612.jpg the grommet on the I5 H3 is in a different location, but it's pretty easily accessible.
IISPEEDYII
Pennsylvania
This X3 but i'll show you how it's doneView attachment 16489View attachment 16490View attachment 16491View attachment 16492View attachment 16493View attachment 16494View attachment 16495 the grommet on the I5 H3 is in a different location, but it's pretty easily accessible.
Haha I gotta start taking pictures of my jobs. My wire is all the way up at the top of the a pillar trim so it would put pressure on the windshield trim. Only difference here
stealth 07
Georgia
Thanks guys this really helps me out and the fuse box would be a good route because I already have enough cables running off my dual batteries. I'll post up pictures once it's all done!
Very fragile, broke mine running my wires
New Jersey
I would suggest a separate fuse holder connected at the battery, that way it's more easily accessible, and you don't have to try to cram more wires into the fuse panel under the hood, sometimes causing it to not even close properly!
