Jiffy Tite Disconnect Tool
rsc
Tulsa
I found it easier to unclip the lines on the side of the engine oil pan and partially drop the transmission 2-3 inches to get to the lines and dipstick.
CaseyS
Louisiana
You can. Pop the clips with an extra small flathead screwdriver.
Are you dropping the transmission? If so lower it first and do the cooler lines last after you drop it a bit. There is not much room at all to get to the lines with the trans up in the tunnel.
If you aren't, drop the cross member and let the trans fall a bit and that may give you enough room.
