05Mudiak
- Lake Charles, LA
I will sortta do this in order kinda and questions feel free to ask.
Starting with rear bumper
Sorry some pics are dark was working at night.
Bumper removed
Trailer plug tab cut off
After much cussing and working by myself. I finally figure out how to line up the top bolts. Line up the bolts on the drivers side first the use the hole were between the bolt hole on the passenger side where the tow hook bracket mouints to move the bumper to line up the passenger side bolts. You can sorta see the orange pry bar hanging in the hole I am talking about.
bumper installed
Front bumper. with ridge demon frame plates, Recon 10.5k winch and Piaa lights
brush guard removed
Grill removed (or is it grille?)
once grill is removed remove the skid plate. Then the bumper upper and lower sections comes off in one big piece with 2 bolts each side at the same spot the Thor bumper monts up to. As you may have noticed my skid plate is not off. It was being a PITA to get out being sandwiched between the lift bracket and frame. So I pulled the bumper first then convinced it to come out but no worries the thor plate slide right in almost like it was made for it
Frame plates welded on (had to grind the factory welds some and bevel the edge of the plate where it meets up the factory welds. Also the ridge demon plates do require some grinding on the top and lower outter corner to fit into the Thor bumper.
After mucho grinding on the plates the bumper is in place and grill back on to take some measurements.
bumper grill and light pods installed. pretty simple straight forward. Oh if you airbag sensor falls out when moving your A/C line it goes back in the round hole in the center support you unbolted to move the A/C line. took me a few mins to figure out where it went.
I didn't take pics of the winch install but with the Recon winch you do have to trim/cut some of the grill for it to fit. You can see where I had to cut this is the best pic I took of it. Sorry. Once it stays warm out I am going to pull the grill back off and smooth out the corners where I cut so you almost won't beable to tell it's cut. I hope.
PIAA lights installed & Finshed!!!
Bumper removed
bumper installed
brush guard removed
