- Scottsdale
Did the Hunner Sleeve install today on my steering rack but added another element to the mix. I put a layer of 1/16 neoprene rubber, 60 durometer, inside the sleeve to make sure the sleeve was really snug plus to add a bit of NVH absorption. The rubber had adhesive on one side to help secure it to the sleeve. Here's the product I purchased: http://www.amazon.com/gp/product/B005I58UGI/ref=oh_details_o00_s01_i00
Sleeve with the rubber ready to go
Taking out the bracket is an exercise in patience and use of varying length sockets to get to the top bolt
OEM rubber insert wasn't destroyed (it broke on removal) but what you can't really tell from the pic is that the top was offset from the bottom by nearly 3/4", meaning it had slid over and essentially re-formed in that position. It wasn't doing the job the way it was supposed to.
Here's the pic as it went in. It is very hard to move the sleeve around once it is in place as this rubber was pretty grippy, so if you try the install this way with the rubber be sure you get the sleeve in the position you want before putting on the bracket. I was told the recommended position is with the "comb" of the sleeve at the top of the bracket (facing the rear of the truck) but I couldn't get it in that position. I could feel the top and the comb was nicely meshed and the rubber liner was in place like I wanted.
I did cut off the brackets tab at the bottom as I couldn't figure out how to get the bracket back on with that tab. It was a very tight fit to get the bracket over the rubber lined Hunner sleeve. Plus, if I ever have to do this on the trail that's one headache removed.
