Sledder10
- Mississippi
So stumbled across some sick extended-travel CV axles for LB7-LMM Duramax's. They use a telescoping shaft and 8-ball joints, effectively doubling their maximum working angle compared to the stock tripod/tulip plunging joint. and they're only $200 a pop!! I thought, "dang, that must be nice. I wish our only extended-travel CV option wasn't $4,500 per side."
I got a little too curious and started brainstorming what it might take to make those DMax shafts work in our H3 application. The most obvious barrier to that is the fact that the 2500's shafts inner joints are a 6-bolt flange mount that bolts to a stub shaft that then couples into the diff. "Could I cut off that flange end and friction-weld an H3 splined shaft on? make a shorter/longer shaft? use differently splined shafts for the hubs?" I was thinking of all the possibilities, and how I would go about asking my school's shop manager to help me make some chop-shop CV axles.
So I looked up what spline count the LMM's stub shaft is: 28 spline--the same as our 7.6". "huh, that's interesting, but there's no way the hub splines will match." So I then looked up the 2500 hubs and they are 33 spline. I looked up our H3 hubs: also 33 spline... and the axle nut is even the exact same M24.
I searched around and found that the DMax shaft's overall compressed length--shaft end to flange mating face--is 21.75". A few inches shy of our ~25.4". But aha, that stub-shaft and its flange takes up some space as well. I'm estimating 2-3ish", as the stub shaft's overall length is advertised as 5" and a couple of those inches will be inside the diff. Might be be a little shy of our 25.4". But if you throw in a small CV-flange spacer (which is apparently common for lifted vehicles with flange-mount CV's) you could easily make the overall compressed length perfectly 25.4".
Maybe this has already been done before??? I can't possibly be the first to notice this.
I am no expert on this stuff; so please let me know if i'm crazy or completely missing something that would bar this theory from working. Currently my main concerns are the actual diameter of the 2500's stub shaft's spline portion compared to that of our CV axle's. They're both 28 spline but IDK if that automatically implies the same diameter and whatnot. I'm also concerned if the 2500's stub shaft would seal up in our diff properly and not leak gear oil.
And if anyone with an H3 also happens to also have a '99-'11 (i think those are the right years) GM 4wd with 6-bolt flange and 28 spline stub shafts, would you be willing to take out a CV axle stub shaft and check if it fits into your H3 diff? If it fits perfectly and seals up... I don't see why this won't work. And that would be huge news for lots of us.
Let me know what y'all know or think about this crazy theory.
https://www.drivetrainshop.com/GM_7_5_7_625_s/108.htm
https://www.drivetrainshop.com/GM_8_25_IFS_s/111.htm
