I've broken 3 anti-sway bar linkages now. Almost every time I go off-road I break one, although on the last trip I broke it on the last real obstacle. I hear it pop, so I know it is always areas that push the articulation limits of the rear axle. However, I'm wondering why I have more trouble than other H3T's and what I can do about it.
I think a contributing factor is the weight of the SlantBack and the cargo slide. The other idea I thought of is the low profile shock mounts could be a contributing factor. With the stock shock mounts and shocks the shocks bottom out before the full travel of the axle. The low profile shock mount moves the shock mount up an inch, gaining ground clearance and allowing move articulation. I believe this may be contributing to my linkage problem.
The next question is what to do about it? I'm starting to get embarrassed asking Tustin Hummer to replace them under warranty. I guess I could disconnect the anti-sway bar linkage before I go off road, but I think I need to check the break lines and anti-lock brake cables to make sure they won't get overextended and break. Also, between airing down and installing my rock rings I’m pushing the time limit. I don’t want another thing to have to do while everyone is waiting on me.
Does anybody know of heavy duty anti-sway bar linkages or quick disconnect linkages for the H3/H3T?
Any other ideas or suggestions?
