Does anyone know if there is a source for a front driveshaft spacer. 4 wheel parts and others have various options for jeep, etc but can't find anything for H3. With the 6L80e swap my growth is just enough I think I have the CV overextended a bit. I put about 300 miles on the stock shaft. I did a quick 4hi lock test on pavement and blew up the CV.
@4speedfunk, I know you have a template done for the double cardan flange that could probably be easily modified to make a spacer. I may hit you up for that if I need. Either that or I will model one up and get xometry to churn me one out.
