OmarOHelmy
- Dubai, UAE
My rear axle diff lock has stopped working, when I press the button while in 4Lo, the button flashes then turns off... The display also shows a message: "SERV 4WD" The diff lock button also flashes everytime I start the engine.
I checked under the car and there was a cable running towards the rear axle, it was rubbing against the drive shaft, the wire got bare and may have short circuited, so I cut it, cleaned the connection and sealed with electric tape.
I checked the fuse box, found a blown fuse, replaced it.
But the diff lock still does not work
Any ideas what could be the problem?
Thanks
Thanks
