BeaverBill
- Spain
hello all,
I wonder if any of you experienced folk can help me on an issue.
Got a 2003 H2 (75000 km's) that doesn't seem to want to unlock the back diff. We select 4 Hi unlock and the rear tyres seems to "skip", feels as it's breaking, hard to move upon semi to hard cornering.
What we've done so far:
...nothing really. Got the rear up on jack stands and changed fluids and filters (engine, tranny and rear diff.) as well as visually inspected the diff, taking off the cover. Liquid out of the diff was "old" with slight deposits but no metal. Looks in good order with only one mental note. (need to post a photo if anyone is really interested since I'm lost for words....a retaining hook on what seems to be a stud for the locking gear on the left side seems to be slightly bent down compared to the right side's retaining hook).
What we plan to do:
Change the transfer case fluids when we figure out how much the tranny will take (GM rep for Spain gave us 7 liters of ATF for the tranny but wonder if he included the transfer case as well as we didn't control how much of the ATF came out of the tranny....we don't have a shop manual aside from my protests ).
What we are scratching our heads over:
What is causing the rear diff lockup?!? How can we test it? With the rear on stands the wheels move in opposing directions when we spin one of them but if we try to spin them from the axel they want to spin the same way (therefore locked, I assume ) We couldn't spin the axel freely (taking into account that the tranny was in neutral, with the fluid drained, motor off and the front tyres on the ground) but the front wheels were on the ground. We gave the 4 wheel drive selector a go and observed no movement in the diff with the cover off but heard the transfer case working.
I've read that there are two possible causes, the actuator for the locking clutch at the transfer case, or the TCCM (transfer case control module). The most common problem is said to be in the actuator. The TCCM I've somewhat ruled it out as it seems to be sending the orders upon pressing the selection with no erratic behavior, but leaves me to ask if I should consider that it is not sending the info to unlock the diff? Doesn't seem very likely... does it?
Moving onto the actuator, what role does it have to play? Does it send information to the rear axel to lock or unlock. I still don't understand how the transfer case has anything to do with an unlocking diff. I can only add that when I selected 4 low (locked) it I got the same sort of mannerisms on the front as well as the back when moving on pavement, full steering lock.
I'm having problems mentally connecting the transfer case to diff lock, any insight on the missing puzzle piece would be appreciated.
If I unplug the connector on the diff does the elocker unlock or does it "fail" in a locked state? Can I tell if unplugging connector on the diff has made a difference with the vehicle up in the air in its current state or do I really need to have the vehicle running to see if it has any effect?
Once again, thanks to anyone before hand in providing any insight.
P.S. obd2 seems to have power as my bluetooth antennae lights up but the software doesn't hook up so I can't read any fault codes. Also....does the obd2 plug (vehicle side) only come with 4 wires connecting into it?! Seems a bit strange...?
What we plan to do:
