Dex-Cool:green coolant vs orange coolant?...
JonBishop
Glendora, CA
Is one better then the other?.... I know the green is more watery and the orange not but jus wondering the differences and if one is better for the hummer :)
Green 1
Matty Patty Pookie Bear
Ferris,Texas
Because the manufacturer spec anti-freeze based on the metal combinations used in the construction of the motor the anti-freeze that is better is the one that meets the specs they have set.
JonBishop
Glendora, CA
Oops I forgot to say sorry, there's a o'reillys dex-cool and it's green, and the other one I believe the GM one, it's a silver bottle, and I think I have the green o'reillys brand in the hummer right now...
Firesquirt
La Quinta Ca.
This is what O'Reilly has to say from their web site;
  • Manufacturer's Defect Warranty
  • UPC: 74804039061
  • Dex-Cool(R) Compatible
  • 1 Gallon
[h=4]Detailed Description[/h]Designed to be used in all cars and trucks requiring GM DexCool. May be used in all other cars and light duty trucks with aluminum radiators. Includes a 5 year, 150,000 miles of protection and meets GM spec 6277, ASTM D-3306 and D-4340. It can help to improve the life of your water pump. Meets the silicate free requirements of Japanese OEMs and meets the phosphate -free of Europen OEMs.
[h=4]Manufacturer Information[/h]We stock quality replacement antifreeze & coolant for your vehicle - regardless of the year, make, model or original antifreeze color. Our antifreeze/coolant brands go through rigorous testing at every level, and meet or exceed the performance requirements of every major car and truck manufacturer. When you want maximum protection for your car's engine, look no further than here.
As long as it is not ethylene glycol you should be ok as they turn to gel when mixed together.
Firesquirt
La Quinta Ca.
I was just looking at O'Reily's comparison chart, and now I am confused, their chart shows all coolants to have ethylene glycol base, but it also reads that the Dex Cool compatible is Orange, if you put in green then maybe you should drain flush and refill with a single known product.
MaxPF
AGNTSA
The dark side of the globe
Dex Cool will be orange. Dex Cool "compatible" or "universal" anti-freeze should be avoided IMO. If you completely change out the anti-freeze, then you're OK, but I would not mix different chemistries.
D
Dennis
What Green1 and MaxPF said ...Stay with Dex-Cool only
I use this
Saves having to mix the concentrate with Distilled water....Even though it says Extended Life..I still change it out every two years regardless..
JonBishop
Glendora, CA
After I fill do I jus start it up an let it work the coolant threw the tubes?.... Lol I have everything changed and coolant is in...
