Cv joint
hummedout
Dallas
What are symptoms of a failed cv joint?
I lost d n 3 in tranny but still can manually shift to 3.
I’ve got some clicking sound and was wondering. If it’s cv joint
Happy Hummer
Wisconsin
I'd high recommend to take the wheels, brake parts, hub off and pull the front cv shafts. I'd also pull my front drive prop shaft. JM2Cents!
Or do you mean the CV joint in the front propshaft? When mine failed it sounded like marbles in a coffee can. The axles usually sound like clicking, like you said. But I doubt that CVs have anything to do with your shifting issues.
HBro
What are your error codes?
My 2007 H3 had a P0787 and felt like only 2&3 gear would activate. I replaced the 3-2 solenoid as well as 1-2 & 3-4 (Battery disconnected)
That fixed the transmission issue
H3Hummer
LUXEMBOURG in EU
For a brocken CV , Uni or prop-shaft , there's no error code, only the issues you can here (clinking parts) , feel (some bad vibrations in axels or shift level) and see .....if you take parts appart.
If you have only transmission issues , I would highly recommande to open it before you have real bad damage !
hummedout
Dallas
Tranny lost 3&4, and yes I pulled it to friends house ,I had the tc,and tranny in neutral and there was a heavy heavy vibration. The clicking is not rhythmic it’s random and not umm the synchronized sound
hummedout
Dallas
Yes sir two diff issues but yes it has heavy vibration n clicking is random
Teahead
Tacoma
How is your electrical system?
My rig wouldn't shift out of 2nd. Turned out to be bad electrical battery terminals; i.e. computer screwed up from lack of juice.
