- Bellflower, CA
I just finished my front end suspension repairs and PCM upgrade. I had the engine idling to let the PCM calibrate and I noticed that there was an intermittent rattle noise. Well it appears that my water pump is going out. Small amount of coolant is weeping out and there is a visible wobble of the fan and clutch. I have already ordered my parts from Amazon, pump, clutch, thermostat, both hoses, and temperature sending unit, all AC Delco OE.. The belt has less than 5k miles on it and it is in good shape.
1. How long has it taken those in the past before it completely fails?
2. Are there any other parts I should replace or look at other than those I listed?
3. I have only ever replaced water pumps on SB/BB Chevys before, how hard is this project?
4. Any tips to make it easier?
Thanks for any help.
