Coolant leak?
poweraidon
georgia
My coolant has been leaking, but there aren't any visible leaks. Do you guys think it could be a blown head gasket?
Hayden
Toyo M/T
Virginia, US
Mine was doing the same thing, i believe it was coming from the seal between the aluminum and plastic on the radiator. But you could never see the coolant. Wasnt a physical crack. Replaced radiator and havent lost a drop
poweraidon
georgia
So you don't think it's a blown head gasket?
Hayden
Toyo M/T
Virginia, US
Any misfires? Check oil and make sure it doesnt look like chocolate milk. Take radiator cap off (MAKE SURE ITS COLD) and check for the same thing. Youll know if its mixed. Are you losing a decent amount of coolant?
poweraidon
georgia
I just took off my radiator cap and it looked fine... Should I drive it alittle then check? How do I check the oil? And yeah I'm losing a lot I refilled it to full yesterday and it's almost all gone today
Hayden
Toyo M/T
Virginia, US
Yeah just take it up and down the street. Pull the oil dipstick out. Im fairly certain its your radiator. Mine had literally the same exact symptoms. I couldnt keep coolant in it no matter how much i tried
poweraidon
georgia
Here is the coolant and dipstick
(the white thing is just the metal)
So you think it's just the radiator?
Hayden
Toyo M/T
Virginia, US
I would say so yeah. Gimme a couple minutes i'll show you where mine leaked. It was just wet not a visible leak but i was losing a ridiculous amount
poweraidon
georgia
Alright thanks man!
poweraidon
georgia
No problem! It was leaking where these tabs connected the aluminum and plastic. As you can see now its dry as a bone. I wish i could find pics of before
I will diffinatly check tomorrow cause I just washed my engine and everything is still wet. And How much did it cost to replace it?
Hayden
Toyo M/T
Virginia, US
i replaced mine with a Silla radiator. $130 and i did it myself. Its a chinese radiator but its holding up good for me and i havent heard anything bad from the others running it
how many miles are on your rig? and is the radiator the original?
poweraidon
georgia
I have about 86k and I think it's the original radiator
Hayden
Toyo M/T
Virginia, US
I just checked and it's the radiator
It's leaking from the side and dripping down
Ok cool, thats where mine was but all the way across. Definitely better than the head gasket and im glad i could help you figure it out haha
poweraidon
georgia
Haha yeah it was a huge relief know it wasn't the head gasket. When you installed the new radiator did you have to buy new hose and other things or did you just buy a radiator?
Hayden
Toyo M/T
Virginia, US
Just the radiator and coolant and some transmission fluid to replace what was lost
poweraidon
georgia
Alright thanks again man! I called a shop and they quoted me 800 bucks for labor and new radiator... Which is ridiculous. I'm just gonna do it myself
Hayden
Toyo M/T
Virginia, US
Super easy definitely do it yourself use alrocks radiator replacement thread
Chocflip201
In the Rocky Mountains
Utah
Man you can switch to an E-fan too and still be under that price.
