Carfax
ABNTROOP
HIPPO
Vancouver, Wa
Yes please!
Can I get a check on
Vehicle:2008 HUMMER H3 SUV ALPHA
VIN:5GTEN13L388102045
Thank you for any info you can scrounge. Would like to know as much as possible and specifically whether it was serviced for the hood louvers.
3rdH3
Blacksburg, VA
It's hit and miss with Carfax. Some dealers and repair shop don't turn anything in to them and some do. The place I had my old Cherokee serviced turned in everything. I had a bunch of entries on it. But the places I have had my last 3 H3's serviced, including dealers, entries have been sporadic at best. If the hood vent recall was done, any GM dealer can run the VIN and check. The things Carfax does best is Salvage Titles and most accidents that are reported to insurance companies. At least that is what I have found. I hope your search turns up clean.
ArtHummer
Gaithersburg/MD
Don't need the VIN just Tag number, state and engine(I5 or V8)
After looking more in to it I realized that it shows only the service history not the full history. That kind of sucks...
Not sure how this can be much of use but in any case...
This is from their website:
[h=1]Have a question? Let’s find an answer.[/h]
  • [h=3]I just purchased a CARFAX Vehicle History Report. How do I access it?[/h] To access a Vehicle History Report that you’ve purchased through Carfax.com, please visit www.carfax.com and click “Log in” in the upper right corner.
  • [h=3]Can I use myCARFAX outside of the US?[/h] myCARFAX is currently only available in the US and Canada.
  • [h=3]Why don’t I see accident information in my Service History?[/h] myCARFAX is a service that helps car owners care for their car. Through this free service you can access your vehicle’s service history to help you track what’s been done. To access the full CARFAX Vehicle History Report please visit www.carfax.com.
  • [h=3]Which service should I use while car shopping?[/h] If you are shopping for a used car be sure to review a full CARFAX Vehicle History Report before purchase. Every CARFAX Report contains information that can impact a consumer’s decision about a used vehicle. Visit www.carfax.com for more information.
  • [h=3]Can I record service that I completed myself?[/h] You can now add your own service records, including records for service that you've completed yourself. Simply click on the "Add Service Record" button in your Service History.
  • [h=3]My service history isn’t showing up. What now?[/h] You may have serviced your car at a shop that is not a CARFAX Service Network participant. Please fill out the form below with your shop's information and we’ll get them set up.
ArtHummer
Gaithersburg/MD
Yes please!
12/14/2012 Dick's Country Chrysler Jeep Dodge
Hillsboro, OR
503-640-1050
Oil and filter changed
VIN glass etching
Washed/detailed
10/10/2012 Gladstone Suzuki
Milwaukie, OR
503-513-6600
State safety inspection completed
03/16/2012 71,379 Butte's Mile High Chrysler Jeep Dodge
Butte, MT
406-533-3634
Pre-delivery inspection completed
Brakes checked
Washed/detailed
09/19/2011 69,315 Wally Mccarthy's Cadillac Hummer
Roseville, MN
651-636-6060
Maintenance inspection completed
Electrical system checked
Washed/detailed
04/25/2011 65,661 Wally Mccarthy's Cadillac Hummer
Roseville, MN
651-636-6060
Vehicle serviced
02/01/2011 Wally Mccarthy's Cadillac Hummer
Roseville, MN
651-636-6060
Vehicle serviced
08/25/2010 Wally Mccarthy's Cadillac Hummer
Roseville, MN
651-636-6060
Hood release cable replaced
07/21/2010 60,097 Wally Mccarthy's Cadillac Hummer
Roseville, MN
651-636-6060
05/10/2010 56,714 Wally Mccarthy's Cadillac Hummer
Roseville, MN
651-636-6060
01/25/2010 52,075 Wally Mccarthy's Cadillac Hummer
Roseville, MN
651-636-6060
Service contract claim
Exterior serviced
Front door latch replaced
Wiper(s) replaced
Tires rotated
Washed/detailed
Cooling system checked
10/06/2009 46,790 Wally Mccarthy's Cadillac Hummer
Roseville, MN
651-636-6060
Vibration checked
08/31/2009 44,863 Wally Mccarthy's Cadillac Hummer
Roseville, MN
651-636-6060
Brakes checked
Engine oil/fluid leak checked
07/07/2009 42,875 Wally Mccarthy's Cadillac Hummer
Roseville, MN
651-636-6060
Tire repaired
05/14/2009 40,203 Wally Mccarthy's Cadillac Hummer
Roseville, MN
651-636-6060
Recommended maintenance performed
Tires rotated
03/12/2009 37,894 Wally Mccarthy's Cadillac Hummer
Roseville, MN
651-636-6060
Vibration checked
12/23/2008 34,580 Wally Mccarthy's Cadillac Hummer
Roseville, MN
651-636-6060
Tire repaired
09/03/2008 29,467 Wally Mccarthy's Cadillac Hummer
Roseville, MN
651-636-6060
Tire repaired
07/22/2008 28,251 Wally Mccarthy's Cadillac Hummer
Roseville, MN
651-636-6060
Vehicle serviced
06/13/2008 26,648 Wally Mccarthy's Cadillac Hummer
Roseville, MN
651-636-6060
Tires rotated
04/02/2008 23,752 Wally Mccarthy's Cadillac Hummer
Roseville, MN
651-636-6060
Vehicle serviced
02/05/2008 20,005 Wally Mccarthy's Cadillac Hummer
Roseville, MN
651-636-6060
Engine checked
12/12/2007 16,157 Wally Mccarthy's Cadillac Hummer
Roseville, MN
651-636-6060
Vehicle serviced
11/06/2007 11,971 Wally Mccarthy's Cadillac Hummer
Roseville, MN
651-636-6060
Tire repaired
Vibration checked
09/18/2007 6,242 Wally Mccarthy's Cadillac Hummer
Roseville, MN
651-636-6060
Tires rotated
07/24/2007 2 Wally Mccarthy's Cadillac Hummer
Roseville, MN
651-636-6060
Washed/detailed
3rdH3
Blacksburg, VA
Looks like the previous owner stayed on top of things. On 1-25-10 it appears work was done under a Service Contract. It may be worth it to you to see if it is still active and transferable or maybe not. Wally's Cadillac looks like they entered things on a regular basis. Good Carfax.
3rdH3
Blacksburg, VA
All those electrical system checks may just be a catch-all entry for a normal courtesy check for things such as lights, battery voltage etc... just depends on who is entering the information. Unless you are having issues, I wouldn't worry about it.
HUMMERDAD
GraysLake IL
I would not trust carfax there are way to many missing reports for me when I bought my duce they gave me a carfax report and it said no accidents yet mine has had someone do enough damage that they destoryed ther right side backing where the daytime running lights are that now I have to replace the whole damn thing. I never knew the front end damage was so bad until I upgraded and put in Delta's fog lamps and saw for myself so be very CAREFUL with that report..
ABNTROOP
HIPPO
Vancouver, Wa
Same issue here. Grille was cracked, & passenger headlight was split between it and turn signal. Had to replace the headlight unit. :/ otherwise been ok as far as I can see.
