H3T Best way to mount high lift jack inside H3T bed with canopy?
2010H3TAlpha
Issaquah, WA
I need to secure my high lift jack inside my H3T bed and mounting options are limited because of the Snugtop canopy. Anyone else found a good way to do this? I'm trying to avoid mounting anything outside of the truck because it'd probably get "jacked" the second I park in a shady area. Thanks!
scoreh3
I've seen a couple of pick ups with theirs mount along the inner bed wall just under the top rail. I would look on high lifts site to see if any of their mounts would work of do a search of high lift Jack bed mounts to see if anyone else makes one .
2010H3TAlpha
Issaquah, WA
Thanks for the idea, I'm thinking using the bottom rung of the utility rail is probably going to be my best bet.
Can't get the link to load for some reason :(
Custom pre-runner gate. You can weld on brackets for whatever you want to stick on it...
http://youtu.be/HsQICruI2o4
I'd like to keep the stock tailgate, kind of defeats the purpose of the canopy if I have a tubular tailgate. ;)
