Accelerator Vibration
HUMMERADDICT
NH
Did a search, couldn't find anything. I'm noticing a small amount of vibration on my gas pedal. Also, brakes do the same. Just had new brake pads at all four corners. Need new rotors next. Also, steering column vibration at idle which has been there for quite some time. Any suggestions?
I vote for the center diff support as one or a combination of possibilities. I know when shifting from D to R when it is shot there will be a clunk. If the rubber has deteriorated and the metal bushing is against the cross member it can transmit all kinds of strange vibrations.
f5moab
Mr. Beretta
In hiding.....
I would agree with motor mounts, but the steering issue I would check the gear bushing. I had that same vibration in the steering column, had the bushing replaced (under warranty, even though off warranty) and it fixed it. (NOTE: I had 50,500 miles on the factory steering bushing and only one side was actually starting to roll.)
HUMMERADDICT
NH
One more follow up to this, will worn brake rotors cause a poor ride quality? It almost feels like I have warped tires, but I know my tires are fine.
D
Dennis
IIRC..back in I think the 07 and into 08 models..there was a known issue with the lower steering rod/shaft and it caused the vibrations as you described here..It maybe the same thing f5 is talking about..I don't know..but it maybe in the steering shaft somewhere..your dealer will or should still have records of these issues..
D
Dennis
If your rotors are warped (which I highly doubt)..the only time you would know it, is when you hit the brakes..Not while driving..
HUMMERADDICT
NH
Wow! Sounded like the Predator with a cold..LOL
So it is while braking only and not driving...do you feel anything in the steering wheel or Brake pedal, while braking?...so it maybe bad rotors or pads or both after all...what is your mileage on these brakes ?
There seems to be some play and a little vibration (uneasiness atleast) in the brake pedal while braking. Also, I have 47,000 miles. Replaced the brake pads about 4 months ago, not rotors yet. Have front rotors sitting on my foyer floor right now, waiting for rears to come in the mail.
D
Dennis
I assume you did the rear pads as well when you did the front..right?
I never put new pads on old rotors and never have the old rotors turned either..I always go with a complete change out with everything new...but that's just me..I hate redoing a project...
I imagine depending on the type of Pads you went with..they probably ate up the old rotors
Just a little advice...If your new rotors are not slotted or dimmpled...then take them somewhere you can trust their work..and have these new rotors checked for uneven milling or runout..I found 1 of my brand new 4 rotors was in need of a mild resurfacing to bring it back in to spec. (would have acted just like a warped rotor)..So have yours checked before installing..it will maybe save you a redo..
HUMMERADDICT
NH
yes, both front and rear. I had acdelco pads and just bought the acdelco durastop rotors
