WTS 2007 Hummer H3 Adventure
BigHollander
MI
SOLD
2007 Hummer H3 Adventure 3.7L 5 cylinder engine Great daily driver and ready for the trails. Everything works great, nothing missing. This has the real Adventure Package with the 4:1 transfer case, 4.56 gears, and a rear differential locker. Upgrades made in the last year: -35" Mickey Thompson MTZ P3 tires -RIGID SRQ driving lights -Front Bilstein shocks, rear Fox 2.0 shocks -Engine tune by PCM of NC. More HP and MPG -CB antenna -Air Doc Intake and AFE high flow air filter -Upgraded rear leaf spring shackles for 1" lift -Rock sliders -Rear shock skid plates - Smittybilt 9,500 lb winch and mount -Odyssey Battery -Iridium spark plugs The following upgrades and replacements were all made to improve ride quality. -New steering rack, steering shafts, tie rods, heavy duty steering rack mount, lower ball joint, bump stops, upper control arms and ball joints, front and rear sway bar links, rear sway bar mounts and bushings, and upgraded front differential cross member with new bushings
