ghilliegunh2
- Houston, Tx
I recently replaced my fuel pump assembly. After reassembling everything the truck ran great for about 10 minutes. Several hours later it would not start again. I removed the tank again and found a kinked fuel line. I repaired this fuel line and reassembled everything. The truck still will not start. Does this truck have an inertia switch that cuts off the fuel pump relay?
